Yesterday Peter Kovacs and I took Pete's 73 Car to the PCNC Tech session, getting ready for Reno! The ride there was nice and uneventful. While there, Pete was to move his car, while in reverse, backed up a few feet and bang! He said it was like throwing a automatic in Park! Forward gear work fine? Any and all thought are welcome!
Mystery Solved! Thank You, to all who commented! Mike Drew emailed Peter, and said to check the rear brakes? Well, low and behold Pete checked and found only ONE bolt holding one of the rear brake calipers! I believe there should be little tabs to lock the caliper bolts? Check your calipers! If there gone replace them.
