The factory manual say to use 80W90 low- phosphate rear end lube. That was written in the early '70s; nowadays, ALL rear end lube is low-phosphate. In addition, the ZF limited-slip is a steel-clutch type similar to a GM Positraction, so I use a discount-auto-parts 75W90 for posi rear ends. Works for me....
