As we all know and have heard, zinc is dissapearing in motor oil. It has been estimated that low zinc levels in newer motor oils has been causing cam failures in older engines. Older levels of zinc were at around 0.2% but new oils can be as low as 0.05%. Few oils still have higher levels of zinc such as Valvoline VR-1 oil. Stp now has a new oil additive that is not that old thick goo. Their new oil stabilizer contains 6 times the amount if zinc (ZDDP) that was in a single quart of older spec motor oil. This means you should be able to add this to a flat tappet cam engine and have plenty of zinc.
Dave is there a name to it or is it just STP?
Hum. I'll bet what they said was that one treatment has six times as much as one quart of the pre-smog oil?
That would give the normal "old" amount contained in one average oil change of 5 to 6 quarts.
I'll ask too. I alsmost ran out to get some when I read this today.
Anyway it is very good for me. I just need to know if I can run it with my Mobil 1 full synthetic?
Thanks Dave. It's a great tip.
Just buy the stuff in the picture below. Its intended for diesel motors, so it still has its ZDDP content, AND tons of detergents. Its a single viscosity motor oil, which means the manufacturer has used a base oil with a more sheer resistant molecule. Notice the label says "heavy duty". You'll only find that on single viscosity motor oils.
I buy it at WalMart.
  • rotella
I'm not in Calif.
No, you are in Florida.
On Feb 18 you posted photos of your car at the ItaliaFest.
Wasn't rocket science to websearch and find the ItaliaFest. Feb 16-18 in Palm Beach, Florida. Track events held at the Moroso Motorsports Park in Palm Beach and the "Concours in the Park' held in Boca Raton on Sunday the 18th, which was the same day you posted the photos.
Some day you might even let us know your first name? Wink
  • Picture_2
