Greetings,
Hopefully the year is treating everyone well. The good news is my move to North Carolina went well and I have now tuned up the car after being in storage for 2 years. (sparks, wires, points, filters, etc.)
The bad news is it seemed to have developed a knock. Would appreciate any insight as to what could be causing this. I have a feeling I know but am trying to not to admit it. See (or hear) the videos below.
Thank you!
William
Videos (2)
IMG_1119
IMG_1118
...In My Opinion...Based Only on the Sound; It Is NOT a Main Bearing, and NOT a Rod Bearing! The 'Tick' Could Be:
1. Exhaust LEAK
2. Loose Valve Adjustment/Failing Hydraulic Lifter
3. Fuel Pump EXCENTRIC
Was the Engine Running at Normal Hot Temperatrure? Lifters will Normally Make a Similar Noise (especially 'Solids'), Until fully warmed up And the oil Pressure is UP (Hydraulics).
Good Luck with It!
… Yes! It could be a Rod Bearing, Spun after sitting for years. Just starting to go and has found 'PLAY'.  A 'Main' Bearing would sound like a Deep Rumble.
