IMG_0180
Is this the A/C relay ? I toned the light blue/black stripe wire to the engine compartment next to the ignition stuff. It looks like this goes to the compressor. I'm guessing the white/blk goes to the switch.IMG_0181
I Toned the white/blk wire to here. I'm guessing this goes to the A/C  switch and the brown to the hot connection on the switch.I need to temperately  reinstall the steering column and plug the ignition back in to verify that.   I have a new A/C control switch that has three spade connectors. I was told that the 71 has two and the 72 and newer has three. Is this correct? On the 71 does the one light blue blk stripe turn the compressor and the condenser on? Help would be greatly appreciated.
Images (5)
  • IMG_0180
  • IMG_0181
  • IMG_0184
  • IMG_0181
  • IMG_0181
