Hi all,
My battery died, so replaced it and had the alternator tested. It was bad, so I replaced it.
When I drove the car the first time the amp gauge jumped around a lot. The second time I drove it the amp gauge was more solid and I figured the problem was solved.
Today the amp gauge always shows a slight discharge, just like it did before I changed the battery and alternator.
Is there an obvious fix that I can do, or should I drop it at the shop?
Robert
