Several Ford Racing Engines for Sale:
Aluminum 6L LMP1 Racing Engine. As used in the Riley & Scott Mk IIIc and Panoz LMP Le Mans Prototypes. Recently re-built with zero running hours.
Currently set-up to fit Riley & Scott LMP1 chassis with front motor-plate.
- Ford Motorsport aluminum block and heads
- Carbon fiber valve covers
- Valve spring oil spray bars
- Roush-Yates belt drive
- Jesel rockers, roller cam
- Knock sensors
- Dailey Dry-Sump Pump with air-oil separator
- Custom low profile CND’ed billet aluminum sump with hard-lines to pump
Offered for sale with multiple intake options:
1. Without intake
2. With custom independent-runner EFI intake from ADA “Le Mans” GT1 Pantera.
3. With custom independent-runner EFI intake using (8) Jenvey throttle bodies with airbox.
4. With Kinsler independent-runner EFI intake.
5. With Elan carbon fiber cross-ram intake (with either 8 or 16 injectors).
Price w/o intake: $28K.
I can also supply the Motec ECU that can be used to run this engine. Price w/intake: depends on options.
Also available:
341 engine with Kinsler EFI intake and EFI Technology ECU. 100% new parts. Never run. Based on Ford Racing A4 block with High-Port TFS alum heads. More info here 341 Ford with Kinsler IR Intake $12K
ADA Pantera engines – as last run on the ex-LeMans ADA Pantera, 5.0 liter, based on A4 iron blocks, disassembled and require rebuild.
Please contact me directly via e-mail if interested in purchasing.
Dave
detomaso.pantera@verizon.net
