I got the regular qa1 5855 poly bushing shocks. The supplied bushings and inner sleeve seem about the same width as the stock old shock ends. I hope it fits and no spacers are needed. Guess i will find out. I did purchase 12" springs front and rear, as I can not lower the car anymore than already is, or will not be able to get it into my garage. But will certainly consider swapping out to 10" fronts on the future.
Seems like it should be fairly painless (I hope). Is it really necessary to remove the either the upper or lower front A arms to install the front coilovers? Plus does anyone have spec for standard ground clearance?
Best jc71
