Where can I get a new reverse switch? How much?, Lou, 72 pantera. Also, When I put a 25 amp American fuse in of the same amp, it blows after about 15 min. Why? Hard to find 25 and especially 30 pointy fuses.
Most of these switches seem to lose the cover plate on the bottom of the switch. Check this and see if dirt, mud, corrosion has shorted out the contacts that are supposed to be covered. You should be able to remove and clean if need be.
Make sure you're using the European type open ceramic fuses. They radiate heat, whereas the glass type trap the heat in and quickly melt the wire inside. Seriously. I found mine at Pep Boys.
