I will do this at a friends shop with his hoist as the car is very low and hard to get under to take all measurements. I saw Joules5 post that says his battery box is 12 1/4 x 6 3/4 inch. is that the max size ? I will be hand fabricating this box and then dropping it in the freshly cut hole.I would rather make the hole as big as possible so I can work out the biggest battery i can buy, and have room for the cables. It will prob be more of an open box, than a sealed box. It will house s dry cell battery that is wrapped in a steel case, so there will be no spillage, and rocks should not hurt it !
may put a bettery switch in and some jump posts as well. not sure yet, but want to make the front boot look clean and empty, as that is the next step on the car and while it is at the trimmers the interior as well !
Thanks for any suggestions
