marlinjackThe Machinist #5723 AMARGOSA MACHINE 'Running on Empty- Middle of Nowhere'
...I believe the 'type one'(very early cars) bellhousing bolts up to the transaxle with(only)4 bolts, Where-as the 'type two' bolts up with 5 bolts; one being on the top-center. I do NOT think they would be interchangable...
