3989's brakes have taken to squealing. The pads look plenty thick, but they squeal nonetheless, especially when cold. The right front also seems to be sticking a bit, since it continues to squeal a little just after brake release. Rotors look OK.
I was thinking of putting in new pads all around. Any suggestions for a good "street" pad?
Dan Patterson
As Mark mentioned, the Porterfield R4S pads are the way to go and I run a set myself. As I understand it, if you call Porterfield mention you are buying pads for a Pantera and ask for the rear pads with the E-brake tab already in place, otherwise you have to fab one up yourself. Last I heard just asking for the "Pantera specific" rear pads with the tab was a no-cost upgrade.
