Wanted: OEM NOS 1 set new front brake pads with sensor wire TEXTAR #V14316FF. 1 set new rear brake pads TEXTAR #V14316FF
Why? The stock brake pads suck. They're barely adequate to stop the car, and even then, only work when heated up. Porterfield pads will significantly increase the performance of your stock brake system.
FWIW - I have a set of original brake pads. These are the pads that came on my car from the factory. They have the original sensor wire and show hardly any wear judging from how thick the pad material is. Are you interested in them? I can send you a pic if you are.
Cheers!
Garth
