Just pulled the wheels off of the 72 in my shop. My jaw dropped when I saw the size of the pads. WOW !!!!!!!!!! Small.
quote:Originally posted by Tom@Seal Beach:
Doug, you mentioned in a different thread that 67 Tbird rotors were used by some of the upgrade factory race cars? I believe you said they were 12" vented rotors front and rear that fit the stock spindles along with an F250 master cylinder? What calipers were used?
Do you have anymore details?
Doug you are right...the replacement rotors I'm seeing online for the mustangs do have the one piece bearing and rotor. Too bad that is one piece...that wouldn't work on the rear.
quote:Originally posted by jb1490:
FWIW
The unavailability of the Mustang rotor only was discussed in another thread on this forum last year. Mike Drew negotiated with Centric to tool up for a special run of just the rotors. This was a special one-time-only run that required a minimum "buy-in" of 20 pairs (40 rotors). Below is a pic of the rotor.
John
