...'Align-Boring'*. May run out of the Spindle Stroke, may be 6" Max Stroke. He is Not Honing as this must be done with rapid strokes to achieve the 60/30 Degree 'Hash' Pattern, necessary to 'Hold' Oil 'IN' the Cylinder Wall for the Piston and Rings to 'Glide' Over.
MJ
* Aligned to the Crankshaft Axis...Centerline, with Zero Error.
