Looking for suggestions for a new carb and new exhaust system for my 74 L. 351 C Engine rebuilt a few years ago to basically stock conditions with the exception of raising the compression to 9 - 1 Have a Holley 650 on it now and have all kinds of trouble backfiring flooding running rough. Looking to replace it, have had it rebuilt a couple times and I am tired of it. Thinking about a Speed Demon upon the rec of a mechanic friend of mine. Any thoughts on this one?
Second, I have a set of Hall Big Bore headers and exhausts on the car. Have been thinking about going to Stainless Steel. When the carb backfired it blew out some of the header and collector tube gasket so it is leaking I figure if I have to take them off anyway, now would be the time to replace the system.
Criteria polished stainless / good sound but not a roar
thanks Gary #06984
The Big bores area actually good exhaust. The look like small diameter pipe, but they really flow well. The make more power than a GTS exhaust. I had them and have had several people with them and they make good power. And they have a cool big block rumble.
The carb can be a big question. I like EFI. But if you want a carb and have a near stock engine, it is hard to beat an Edelbrock 750 cfm. They just run good right out of the box. The only down side, is that they can cut out a little in extended corners. Not sure why but they do.
Gary,
I've never run a Barry Grant Demon, but I can tell you the mighty 351C likes a 750 CFM Holley. Barry Grant measures carb flow differently than Holley, the Demon flow numbers are smaller for the same size carb. A 750 Holley is equivalent to a 650 Demon.
I'm not sure if anyone is making stainless exhausts for the Pantera. I know you drive yours a lot, so if you feel anything like I do, quiet is important. I like the GTS exhaust for that reason, I'm not claiming its the best at making power, but it is reasonably quiet and performs better than the stock exhaust. Dave Berman is making more than 500 bhp with his motor, breathing through the GTS exhaust system.
Pat Mical makes a Pantera header I can recommend without hesitation, they are expensive, but a true piece of craftsmanship. I don't think they're made from stainless, Adams Hudson can answer that question for us.
The only other muffler I've heard that didn't sound too loud, was the Magna-Flow muffler, which are the mufflers sold by PI Motorsports. The drawback is they are too darn long, if I was going to run them I would have them cut shorter & re-welded, now we're talking more bucks.
Good luck with your search.
I can vouch for the Pat Mical headers. Pricey but outstanding quality. We talked at length about the use of SS and he was against it. His headers are coated inside and out with something similar to JetHot. They come with a 3" collector and a the extension to mount whatever muffler you choose. They also come with a bung for an oxygen sensor.
Given the option again I'd would go with EFI. Cost is a factor over carburation. I'm having problems with my Demon but they may be due to "operator error".
Originally posted by Cowboy from Hell:
Gary,
Just saw this post. My Pat Mical headers were twice as costly, but - in my estimation - 4 times the product. He's got the dyno figures, but for starters, the primary and collector are both larger, they mated up to my STOCK Ansa (early style) after opening up the end, and sound beyond belief. Personally, I HATE loud, but love performance-tuned sound. This car sound better than any car I own; just menancing enough but by no means a rattly annoying sound.
As far as craftsmanship, the headers were sent to Jack Roush's #1 specialist for install, who said, and I quote - "All our products are first-rate, but this is the nicest set of headers I've ever seen." They were ceramic coated in 'stainless steel' look and after 500 miles look as good as day 1.
CASE IN POINT: I was at a car show Saturday. Maybe 60 cars, mostly friends, not a judged show. A Lamborghini Gallardo, Ferrari bb512 (mine), twin turbo Porsche (my former car) with a $4500 exhaust (sounds and performs unreal, highly researched, called "PSI"), plus all manner of great muscle cars, the nicest Cobra kit I've ever seen (really), plus "M" powered BMWs, Ferrari 360 with aftermarket exhaust, a V12 Mercedes, and more than you care to read about.
Basically, this was a GREAT collection of horsepower and tons of very critical ears were around. AT LEAST A DOZEN of them came to my Pantera to marvel at the sound and look of the exhaust. Honestly, it was a 'hit' of the event.
Pat Mical is also a champ to deal with. HIGHLY recommended, built my suspension too. pat@patsauto.com or call him at 1-978-649-2211.
Honestly, if I had another Pantera to 'redo', I'd send it to him the first day. Call him and get the best.
