Well, I'm trying to diagnose the charging system and would appreciate any pointers.
Here are the symptoms ...
1) The amp meter got extremely hot on a run recently (no smoke, but the metal bezel around the meter was almost too hot to touch). The normally green needle turned brown and got itself stuck at +75 - a few good taps and it came unstuck and fell to zero again.
I pulled the meter and it has been upgraded to better-than-new wiring and the bolts were good and snug.
2) The battery has been leaking out from under the caps every time I go for a drive (I assume it's being over-charged and is hittting the boiling point)
What do y'all think, does this sound like the regulator is shot, or something else?
