Help!
I have installed a brand new long throw slave cylinder with a brand new Wilwood master cylinder with new braided stailess lines.
I adjust the clutch free play and have the stop bolt just touching when everything is perfect.
I push the clutch pedal a dozen times or so and the stop bolt is now about 1/8 inch away from the stop. It is impossible to push the slave cylinder piston back to where it was. It acts like there is a one way check valve somewhere and it forces the clutch slave cylinder to slowly creep out with each pedal push.
Have taken everything apart but the master cylinder and eveything looks fine. Have bled and bled. Pedal rock hard.
Just keeps creeping out!
Any ideas are DEEPLY Appreciated.
Thanks,
David Finley #3659
David; Combination of the two previous posts. Strong spring should push the fluid from slave cylinder back to master; however, you state it is impossible to push slave piston back. If your stainless line is replacing the original line, what happens if you should loosen the line where it is connected under the chassis near the cross member? (Hate squirting brake fluid) Should you relieve the pressure at that point, I would suggest the master cylinder is building pressure with each "pump" of the clutch pedal and not allowing fluid to return.
You stated you also replaced the master. Not familiar with your specific application (correct application?), but are there any adjustments with the rod from the clutch pedal to the master cylinder piston. It appears the piston in the master cylinder is not returning to the point to permit the return of fluid.
