When using a Center Force diaphram pressure plate. Does the release bearing or the hub need to be modified?
quote:Originally posted by Mark Savage:
Centerforce lists their DF021057S for the Pantera application. It requires a flywheel with a 5.0 mustang style bolt pattern and uses the standard pantera release bearing. The only thing "special" is that they drilled the pressure plate holes for larger bolts.
I used the DF700000. It is the old 11" ford diaphram style. It requires a .250 shorter bearing. You can cut that much off your bearing carrier or as I did, use Mcleod's adjustable bearing #16525 and remove both spacer rings.
regards...Mark #3461
quote:Originally posted by 4NFORD:
ADJUSTABLE #16525 - .200" SHORTER = 2.025
ADJUSTABLE #16525 - .400" SHORTER + 1.825
quote:machine my spare bearing carrier for the clearance.
quote:Originally posted by LF - TP 2511:quote:machine my spare bearing carrier for the clearance.
I might suggest that for those of us without a spare carrier, the McCleod adjustable bearing has one big advantage....
Pantera ZF specific bearing carriers do not cross the parts counter at NAPA or Pep Boys. Never have and never will. And what their availability will be years from now is anybody's guess.
Modifying that part for YOUR purposes today will very likely create a major problem for the future owners of your car. Your well-kept records may be long-lost thirty years from now, and some poor soul is going to have NO IDEA what the heck is wrong with his throwout bearing geometry.
My 2¢
quote:The only problem would be if you wanted to go back to the stock long style pressure plate, the T/O bearing would sit .400" too far back and you would have to shim it forward.
quote:Originally posted by LF - TP 2511:quote:The only problem would be if you wanted to go back to the stock long style pressure plate, the T/O bearing would sit .400" too far back and you would have to shim it forward.
Precisely.
And 30 years from now when someone can't figure out why the stock parts he bought are no where close to working, the tell tale machining signs on the carrier are long obscured and not noticeable, the poor guy will be pulling his hair out trying to figure out what is wrong with his installation.
