I need some tips on getting the back glass out, preferably without breaking it. Does it come out forward, into the cockpit - or rearward, into the engine bay? Should I start working at the top first, or the bottom? Thanks!
if the engine is out its easier to remove from behind cockpit. try removing from one of the corners. if you break it which you most likely wont i have 3 in stock. mike mayberry....
