Morning all,
just mocking up the engine bay insulation. Unsure of how the coil was originally mounted? I've highlighted 2 holes in the body in blue where I think it's mounted, looking like it would have to face downwards? The hole marked in red is where it was fitted.
Also, I've got the heater valve bracket fitted on the LH, near the expansion tank. I've noticed on photos from Leea, and another car that the bracket is on the RH. I've rivets where it could be mounted, and the cut out on the original insulation. The bracket is riveted on, and looks period.
Someone in the past had mounted the valve in the front tub area, with a cable attached to adjust. Where does the original cable go?
All very confusing! Thanks in advance as always!
