Originally posted by DannyOcean:
Sorry, not trying to hijack the thread, but...which tank is which? I have two tanks on the pass. side of my engine, one rearward and one midships. Both have pressure caps.
Thanks in advance.
The rear tank is the swirl tank that coolant circulates in. The midship tank is your overflow or coolant recovery tank
Hey Will,
What do you need all the room for? Some new monster engine? Blower? Twin turbos? Wink
I just cut the old bracket off and tucked my two cans (in the Hall bracket) under the passenger side engine cover panel. Easy to get to (for me anyhow, as I have no rear window) and lots of access to plugs, wires, PCV system. And of course, convenient for my frequent oil top ups every couple of hours.
  • tanks
Will,
the hot tip is to eliminate the swirl tank and overflow tank, and install a surge tank plumbed into the suction of the water pump, such as at a water pump heater hose connection. The surge tank will have a pressure cap where fluid can be added. All air bleeds are plumbed to the surge tank as well. I suggest a minimum of two air bleeds, one at the radiator inlet or outlet and one at the high point of the system which should be the outlet of the motor.
I will be doing this to mine, I plan on converting the overflow tank into the surge tank (requires a bit of modification) so as to keep the engine bay looking reasonably oem.
Issue 116 of PI magazine has an article by John Taphorn, who has performed this mod to his cooling system.
George
Originally posted by 4NHOTROD:
I'm looking to relocate my coolant bottles or delete the swirl tank completely. Does anyone have photos they can post to give me ideas?
I'm thinking about putting an inline pressure cap in the system and a remote overflow tank.
Will D.
Hi,
I just did a major relocation and cooling system modification to my car last year and it works. Getting the surge tank out of the high pressure side of the system and eliminating some of the twists and turns in the system helps cool these cars. I have Arizona summer desert testing to prove it and I only run a ten pound radiator cap now. You don't have to relocate the tank, but you do need to vent the upper part of the radiator back to the top of the surge tank and also get rid of the thermostat housing pipe that goes to the top of the tank. I can give you more ideas on this if you send me an e-mail. I didn't take any photos of the modification and it is hard to get photos of it once it is intalled.
Hi,
wdemelo@cogeco.ca
Will D
