How is the upper window frame attached to the door? The rear vertical frame is broken off the door structure.
I can not recognize any other welded connection to the door, only a small weld spot at the transition from door skin to window frame. But this small welding is obviously not strong enough. Whereelse should it be fixed? Currently, the lower end of the window frame is loose in the door frame; not welded, not screwed. Looking forward for any ideas.
