Does anybody have an "easy" way to remove the pilot bushing holder from the crankshaft? I have soaked it with penetrating oil and used a slide hammer, but it will not move. This is for the dash 1 ZF. I don't want to destroy it, but that may be the only way to remove it.
John
  • IMG_0023
John,
The old school idea on this is to pack the pilot bearing recess full of grease, totally full of grease.
Then slide a spare input shaft, or perhaps a clutch alignment tool, in the hole and start pounding.
With no place for the grease to escape, the theory is its compression from hammering will act as a hydraulic force to push out the only thing that will move - the pilot bearing - or in your case, the adapter.
I have not personally needed to try this out.
But have heard of it working for others.
Good luck.
The first time I did the grease 'hydraulic' method I was somewhat surprised, I had tried everything else prior with no success and low and behold it came out a doddle. The trick is in getting a shaft that is almost an interference fit in diameter so the grease can escape around it.
Good luck,
Thanks everyone for the suggestions. I was avoiding the grease method due to the potential mess. It is the method that I finally used (did this before seeing Paul's post re the terlet paper). I had also considered tapping the shoulder at the bottom of the bearing holder (see pic below) with a 5/8" tap, then using a 5/8" bolt that would bottom against the crankshaft. Like Julian, I too was amazed at how easily it came out.
To use the grease method, I had to find something that would just fit into the bore at the bottom of the bearing holder. I was unable to accurately measure this bore as it was recessed too far. I finally found a socket that fit the bore (sort of). I added metal tape (one wrap at a time) to the socket until I got a snug fit and then measured the final diameter.
Then I went to a friend's shop to use his lathe. I used a piece of 3/4" stock and turned one end to a slightly larger diameter than what I had determined to be the correct size.
I went home and tried the tool. It was just a little too small and wouldn't work. Crap!! So I drove back to where the lathe was and turned down the other end of the 3/4" stock to a slightly larger diameter than the first attempt.
I went back home and tried the tool. It fit perfectly! A little grease, a whack with the hammer, and the holder started to move!!
Here is a pic of the tool, bearing holder, bearing, and spacer(?).
  • IMG_0025
John,
What was that little spacer thingy? A cork seal of sorts????
I chose not to run the needle bearing as I had one seize up on my 68 Cougar. Caught it just as the grease was hardening up.... But that was a daily driver...stop-n-go...but you got GREAT life out of it if yours was original!
I used a bronze oilite verion and machined it down to fit. I would only get about 1/2 of the width of the bearing for engagement with the input shaft.... (Mangusta)
Are you running a block plate between the bellhousing and the engine block?
Steve
It is a seal for the pilot bearing. It has a metal housing with a rawhide?? seal, kind of like a miniature wheel grease seal.
Yes, it is the original.
Yes, and it is the original plate.
Are you going to make Monterey with or w/o your car?
John
Steve,
I didn't need the seal, as I changed to the -2 ZF. Apparently, that seal is used with the -1 (-1 1/2) that has the steel adapter in the back of the crankshaft. It is used to seal the pilot bearing.
That seal has the same OD as the pilot bearing (ie the ID of the steel crankshaft adapter), and the ID or shaft size is...you guessed it...the same as the ZF input shaft snout. The seal measures ~.202" thick. Kind of hard to measure exactly, as the back side is a little rough. No Numbers.
I just looked on Wilkinson's website, and it shows that "seal" as two pieces...a cupped washer (bearing retainer) and a felt seal..hard to tell for sure without cutting into it. I guess that the felt was nicely polished after all those miles so that it looked like rawhide. Here's the link, #7 & 8.
http://www.panterasbywilkinson...s/catalog/ill9a.html
See you in Monterey!!!
John
