I do not know the dimension you ask for. I will however explain how I set up my dipstick since I an using an aftermarket large capacity pan. I believe the pan is a 10 quart pan. I run 9 quarts. I filled it up with 8 quarts and marked the stick. I added one more quart and marked it again. I now have an 8 quart mark and a 9 quart mark. You should be able to do the same with a stock pan too as long as you find out how much oil it is supposed to hold. Hope this helps
On drag-race pans with deep sumps- a stock or custom stick will not be correct without work.
I've heard this before, and it leaves me confused every time.
Isn't the critical factor for proper oil-fill the level of the TOP of the oil in relation to the crankshaft?
How much oil is below that level is of no importance.
Whether a stock five quart oilpan or an aftermarket 8-10 quart oilpan makes no difference.
The crank doesn't move. The dipstick (and its markings) doesn't move. Just the bottom of the oilpan moves.
A properly marked dipstick will remain properly marked, regardless of the oilpan depth.
Flame suit on.
Cool
Flame suit on.
Cool
You are correct. Don't sweat it.
