There is no male small diameter cap made for the ford distributor BUT I found a small cap that works.
It is from an International Harvester and is NAPA part number AL162 SB.
I use it on my car because of the Weber carbs amd the wires I use.
I don't have the rotor number but that is no problem. When you buy the cap just ask them for the rotor for it.
Also this is the number for the cap with the aluminum contacts. There is also one with brass terminals which costs more.
