I took the old shorty points distributor,took out the points,cam,base plate and vac advance pod to just go with mech. advance and put in corresponding elec.
ign. parts.Can't find any other dist. housing to clear the webers and manifold,
any opinions? Also, anyone know the correct
spacing for dist. gear? Dist.seats 1/4" to
highand with grease on bottom of gear,it goesover the pump shaft but gear looks like it bottoms out at the stop. Thanks
If I understand your question, the Ford 460 distributor is a drop-in swap to the 351-C, although you may have to swap out the drive gear on the bottom for a 351C gear. The 460s wide cap, cone adapter & big rotor simply pulls off and a stock 351C cap & rotor fits in place. This solves the wide-cap-hits-the-firewall bit as well. The early 460 brainbox adapts to the Pantera wiring fairly easily. Your other alternative is a crank-fire ignition, possibly with a 4-coil "distributorless" setup from Electramotive (there's still a stub-distributor to drive the oil pump, though). If the distributor won't set fully down, you likely have the wrong gear, probably a 351W. If run this way, it will destroy your cam gear in 50 miles. Gear spacing is most easily set with the front cover out; the bottom of the distributor hole in the block can be seen if the cam is not installed. There should be "some" clearance between the block & bottom of the gear. Drilling a 0.020" hole in the oil gallery plug just behind the drive gear will add a pressurized oil spray into the gear mesh, prolonging the life of this fragile gear.
