I would like to take some detail pics and try doing vids, BUT the temptation to just DRIVE overcomes.
5177 is now stored in a different building rather than the shed it stayed in 20+ years.    I added a centering line and delineators to help keep me straight.
open the rollup and fire it up, walk the exit to ensure it is clear
back off the concrete pad and into the yard.   did show, but I have to angle due to transition and spoiler draggging.
down the long dusty path to the paved road.
head into town and first fill up of 91 non-alcohol.
went for about an hour just cruising the back roads.   the engine seems to like ~2200 rpms, giving me ~55 mph in fifth.   I found listen to the tone makes an excellent "cruise control".  Having to down shift as approach a stop is a little strange, but not engine braking but just keeping rpms up without just coasting.
Pulled back onto the dusty drive.  I got the Panther mascot, but no "Farrah Fawcett"
can't wait for tomorrow's excursion.   Would like to drive to diner, but between the altornator might not keep up with headlights and more so my night vision I won't try
Images (6)
  • blobid0
  • blobid1
  • blobid4
  • blobid3
  • blobid5
  • blobid2
trying to figure out how to take and edit vid.    don't know why out of focus.
cold start   https://youtu.be/mMZrxXaltxY
I discovered a driving idiosyncrasy I don't recall hearing before.
when I released the clutch, the toe of my shoe was "grabbed"
does my steering knuckle look like it is the the right place.   This is a new piece.  any comment about brake pedal.
  • blobid0
500 miles today!   no trips just loops around neighborhood.
the plan is, make notes of what needs to be changed, then back to shop after first of the year.
i am having dexterity problems and finding first is a challange for me.   i took a cabinet hinge and made a reverse lockout.   WHAT a differance to be able to push to left and pull down.  I now don't have to hold clutch down at stop light.
THANKS to ebay's "barbaram442"  i now have a working lap and a set of 72 shoulder belts.   i used a7/16-20 x 1" bolt for anchoring shoulder belt.
those belts are a pain.   lap belt "locks" and keeps tighting and can't pull out till full retract.   the shoulder has to be hooked in lap before buckling
  • blobid0
Hey John!  Glad you got your car back.  !  Is is overheating?  The air deflectors made a difference with the stock radiator at road speeds.  I struggled with overheat problems for 10 years before we figured that the orifice under the thermostate was too big and never would stop off the bypass.   I see your brake pedal and I cut the bottom corner off mine and it cost nothing and makes a huge difference when driving!
  • DSC00756: cut brake pedal
Thanks for the "experiances" lessons learned !
the driving tecnique and muscle memory going from one car to another got me.   I hopped in the TR6 to run to town for gas (and keep battery up) and almost wrecked aproaching stop sign,   all THREE pedals responded different.
as for brake pedal, the fact that it was lower than throttle.   (opposite on TR6).    I think I have a tecnique that will work good as I continue to use it,   that is keep the right heel on floor and "turn" foot from throttle to the lower brake, using between toes and ball.
sort of same thing with clutch, keep the heel on floor (inline with clutch) then raise slightly to use between toes and ball, instead of arch.
both of those have me thinking about a "heel rest".    shaped something like wall mounted bottle opener!
I have not removed tube to even look at the AC condensor and its sealing for air flow.    (I had wanted the "L" trunk profile made like earlier car for more air exit flow, but didn't want to delay in driving)
"I" think the side shields are needed but didn't want to be more "picky" for taking care of any items noted during my driving.
With the car moving, I did have one segment where I "thought" the radiator temp was not dropping and the fans stayed on.   that was based on battery voltage stayed low at speed.    I have three points in coolant system for measuring temp.   the Holley Sniper sensor and display are at the block position, the console gauge and its sensor in the water pump inlet (radiator return) and the idiot light switch in swirl tank (can't recall its setting) and the coolant fan swith in the radiator exit upper side tank (i also don't know its setting but think I reqest about 160"
Most times at road speed sniper temp is 185 to 190 with console gauge abot 170 (just right of 160 mark).   I have very little time in stop and go traffic, temps do go up.   have not been there to see if temps level out above 200F.   (currently running 7psi cap (on pump suction).   Shutting down HOT after slow roll down drive, there has not had gurggling as coolant temp rises during heat soak.
another question. . .
When tighten shift linkage lock nuts, holding Gate in center L/R in 2 / 3 path is done, BUT how do one hold the trans shifter shaft?    ( In my long ago thinking bouts, I drew up a radial fine adjustment "clutch")
question . . . can the shifter's gated plate be removed, or does it hold something together?
after last week's adjustment of the turn buckle, the as left was not really that good, but all gears could be selected.   after hour drive, i am not able to select fourth and fifth takes about as much force as i want to use.  definately feel the shifter and gear box detents are not aligned.   not sure if the "new" linkage has hysteresis/clearance issue.
thinking if i loosen / remove gate i can ignore the shifter detent and at least drive some more.
When tighten shift linkage turnbuckle lock nuts, holding Gate in center L/R in 2 / 3 path is done, BUT how does one hold the gearbox shifter shaft?
do the lock nuts need to be gorilla tight or just good enough
  • blobid0
My brake pedal is also higher than the accelerator. This is why cutting the corner off the bottom right of the brake pedal helps get your foot off the gas and ON the brake.  I actually think I would prefer the gas pedal to be higher though.
cut brake pedal
There is a restrictor bracket on the accelerator pedal shaft. I am not sure why it is needed but if you remove it you can readjust the gas pedal to be higher.
Clipping the corner on the brake does help for foot room. I did that to mine also.
the weather was suppose to be rainy, but just cloudy and misty.   I thought that would be good lighting to take some pics.   (then took an hour drive!)
the dash was original covering, but from another since mine got "lost".   the rocker wiper & washer switches were move to gauge console.   the emergancy flasher switch moved to the dash illumination rehost position.  the light between speedo & tach is now a two color LED that provides warning of "low oil press" as blue and "high coolant temp" as red.   the small display on right for the Holley Sniper fuel injetion.   the left is Garmin 55.  steering wheel is Nardi that was when I got car.   the heat / ac controls, the lower lever is conected to double swith, center off, left turns on AC compressor and right opens heater solinoid  valve
side / front / rear views
corner views
some of the details i wanted
replace the "L" bumpers with bright bumperettes and the alignment of those with the hood gap,
another the fitment and angle of the front spoiler.
(i am thinking . . . putting a wood "skid" under the recovery hooks, 1/2 X 3" oak)  ???
AND the exhaust tips !
the tire lettering , the valve stems and center logo all were indexed.
a challange was my desire to have an original air filter housing fit under the engine screen and not tilted.  my fiberglass tube had been shorten (for as purchase turbo installation).   But it gives a good view of engine.
my center engine screen had a little rust on the end strips so They got a New one from one of the vendors.   I don't know which one.   Does this look like something that maybe came on an earlier car.   that is the solid section is just tack welded to the screen !   looks cheap to me, (but it sure wasn't).   the gloss paint has dust stuck to it.
Images (14)
  • blobid1
  • blobid1
  • blobid2
  • blobid0
  • blobid2
  • blobid0
  • blobid5
  • blobid8
  • blobid6
  • blobid4
  • blobid7
  • blobid3
  • blobid9
  • blobid10
delemma ? question . . .
I have a tire (right/front) with a slow leak, less than 2 psi day.
given I am "aware" now, would you top off pressure daily and drive.   (or bite the bullet and take tire to a shop while car is in the shed).
drive now and let restoration shop correct when car goes back in Jan/Feb.   (or just let car stay garage till then )
spent long time, from different angles and don't see any thing in thread and the nut for valve stem is tight.
I can't see the details of the transition from screen to solid, however from what I do see, that is made the way one on 5177.
My comment about dust is my path is very dusty and a gently spray of water did not rinse my screen and I was making excuse why mine was not clean.  proably static or maybe residue vapor from new engine.   thinking I will need a "mop" to wash it.
any ideal on a torque value for the valve stems.   I noticed at autozone, the package stated about 30 to 40.   where I think I only went to 15 INCH*lbs.
edit  . . . thoughts on wheel valve stem torque.   the instructions gave tighten value with no air pressure in tire.   I'm thinking air pressure would compress the rubber seal more and thus the stem nut would loosen, so maybe lower torque is expected and should be used?
Your fill plug is still good as is.  You can make it nicer by removing the sensor and installing a recessed hex plug.  If you want a new fill plug it is best to go to a Pantera vendor.
Here is an example hex plug for $4 that could fill the hole where the sensor is.  I am not sure about the size you need but here is 3/8".  You might need smaller.  If you go this route be sure to put sealant on the plug threads.
https://www.autozone.com/fitti...BwE&gclsrc=aw.ds
@jfb05177 posted:
the heat / ac controls, the lower lever is connected to double switch, center off, left turns on AC compressor and right opens heater solenoid  valve.
Great innovation!  How did you connect the lower HVAC lever to open the heater solenoid valve?
A list of parts/part #'s please!  I'd like to do the same with my car.
Thanks!
I got vary little info on how things were done (  and they prevent car owners from talking to techs, a dollar per hours thing)
I saw invoice for a push pull windshield wiper. .not sure .   it is a swith with center doing nothing, lever ti left turns on compreesor,   to the right opens electic soilold  valve for heat.   But no way to modulate.   so far not been warm enough to test ac for comfort.   for the heater, once chill is knock out, cutting heater off, just running fan and engine keeps you warm
Now.    I know it would happen ....but not this soon....darn squirel ! broke right side front spoiler from valance.   had to ease back home with it a flapping
also didn't realize how fragile the spoiler would be.   any comments on how to repair and make better.    If I get new, still need a way to make better (holes very close to edge)
Images (2)
  • blobid1
  • blobid0
yes, PPC is out of them and no definite plans to get them back in stock.
They are made out of ABS plastic and if you want to strengthen/splint the, I would suggest locating some ABS sheet plastic and grabbing some ABS glue at your local hardware store. Glued onto the backside of the spoiler the splints will be invisible
it looks like you may have torn one of the bolt holes. ABS will bend easily with a heat gun to create a splint for the lost hole.
And yes the last batch from Dennis was trimmed much too short and mounting them was a real pain.
I took my ABS sheet plastic and fabricated mounting tabs, attached them with ABS glue, and then reinforced with Plast-aid.
IMG_8763
I also used larger bolts than supplied by Dennis and installed Nutserts for a more professional installation.
63375863370__43FD12BE-0FFC-4B42-9F0F-7767FC4B6D1ALarry
Images (2)
  • IMG_8763
  • 63375863370__43FD12BE-0FFC-4B42-9F0F-7767FC4B6D1A
I love the look of that flat blade spoiler, and have received many comments on it over the years. But mounting has always been a challenge.
it does not come with any indication of where the holes should be. Dennis supplies 10-32 nuts and bolts but I’ve never mounted it in that matter. Prior to the Nutserts I used self drilling sheet metal screws.
Oh, well.   What was done is done.
First, I wanted to show my kit I gathered for changing trans axle fluid.
The 17mm VW oil plug socket and a ratcheting wrench worked great.   Using 5/8 vynal tubing and a plastic elbow I made the funnel.  For the fill plug with temp sensor, I just got a new plug
To drain, I just used the tire scissor jack to  reach bottom plug.
This was the First concerning finding.   The magnetic plug was FULL!
After draining, cleaning plug and refilling with about 3 ½ QUARTS, the amount in the pan look less, so I filled the emptied bottles and discovered only drained out less than 3 PINTS.!!!
The car had been over 2000 miles mostly under 60 mph.   I now hear a “gear whine” that is more noticeable that exhaust roar at 70 mph light throttle.   Coasting or some throttle reduces the whine.
Images (2)
  • mceclip0
  • mceclip1
I provided PennGrade Classic GL-4 80W90.   I KNOW that is what in used.
the ZF had been in barn storage for 3 decades with oil in it.
Ron Mccall rebuilt 4/16 and it remained in warehouse storage till mated to engine couple years ago.  first  test driving 12/23
there was no bad smell when drained.   hard to tell new from used, the new has a blue tint.
Images (2)
  • mceclip0
  • mceclip1
I made changes to my dash layout.
the Sniper display was originally taped beside the ac duct.   using ABS sheet, I fabbed a small pod that put it between the speedo and tach.
I took the front bumper emblem and mounted it in a horn button replacing the Nardi button
and a dash clock/stopwatch taped left of steering wheel
Great drive today.   trip on twisty two lane for late lunch.   even though a NC highway, very little traffic.   approx 120 miles round trip  (NC27 Benson to Carthage "Pic N Pig")
  • mceclip0
21 feburary, 2024. . . 5177 took a trip back to Klassic Kars, for some Warrenty corrections.   Mainly electrical, larger alternator, brighter dash lights, & turn signal switch.   Mecnically, the rear suspension was raised,  rekeyed all locks, the ABS front spoiler repaired and radiator side deflectors installed.
Delievered early this AM.    Heat and humidity in danger zone today and for next week so debating how much driving ir if I should do a trip
Images (2)
  • mceclip0
  • mceclip0
question about air conditioning ?
just how good should I expected.   NC today is high 90's, sunny and high humity.
my older pickup and SUV will require going less than max after an hour drive.
however, after 30 / 40 drive today I was tempted to lower the windows giving I was uncomfortable sweat.    Diffinately would not want to drive several hours.
the air out of the two dash vents was cool at hand but warm by the time it made it to face.
supposedly I have a new rotary system fitted into the original box.
when delevered yesterday the primary tech suggested I get glass tinted to max legal
@jfb05177 posted:
I let you know if my “upgrades” are working…
-outside air intake to 25% of the fan
-air outlet for cabin air
finishing up a multi year resto on my 1972 and I run a AC compressor  OEM Sanden 4663. R134, all new lines, new evaporator  and orig condenser.  A/C is all stock and in stock location.  I have 2 ball valves in the heater lines and yesterday at abo50ut 5pm NJ time it was almost 90 degrees and dripping humidity and went out for a 30 minute drive and had mid 50 degree coming out the vents and with the infra red shooting inside the vents it was as low as a constant 34 degree.
  • IMG_20230802_115621
I think so and should, it is what I requested and I switch the heater on.
I feel that by the air out the vent not being warmer than the cabin with compressor switched off implied the electracal heater valve was blocking pretty good.
I noticed I have access to short sections of the tubes connected to the evaporator, I plan to attach thermal couple there for latter testing.
(the heat/humity today hit me pretty hard today so didn't spend any time outside)
back from shop Friday.
replace holley sniper fuel pump for the lost of power
programing changes to help with stalling
wired up windshield wipers
said AC was as good as they could get it
next morning early, took a 300mrt drive to car show in Southport NC.   No trophy but horse from all the people I talked with.   drove back through a down pour !   trip down in high 90's and HUMID.   car ran hotter than I thought it should    Think I lost 5 lbs in the sauna!
  • mceclip0
while It won't help with operating temp, I added a over flow tank to my header tank vent.   it is 24 ozs, which is about the volume of air in my cold header tank (coolant thermal expansion volume).   when cold, over flow tank is empty and full when hot.   keeping the header tank full hot & cold, thus coolant reaches cap pressure at lower temp.  I mounted it using the right rear wheel well sheild bracket.
Images (2)
  • mceclip0
  • mceclip1
I had the same problem with the collector flange bolts / nuts.  Mine were double nuts and they still worked loose.  After the third time, I replaced the nuts with metal locking nuts...problem solved.
I suspect that there is some "seating" that takes place with the bell / ball ends after a few heat cycles and vibration.
John
the shop bought new, shifter to ZF, but didn't adjust to go easy, just FORCED shifts.   Telling me that was the way it should be.!   I haven't checked to see if it could be an easy correction.   I've been driving without gate and side to side free play is a lot.
as for collector nuts, I went with old school long brass nuts.
  • mceclip0
i think the shop bought every thing in the Wilkinson catologe.!
they initially used the rubber insert trunion, But I insisted they use a sperical bearing.
It should have been perfect, but I think the forceful shifting during testing loosen things up.   the free play requires shifter sliding along side of the upholtered frame,   ie where the gate was machined to.   with 2/3 is pretty close to center, (some times requires a little side to side wiggle)
correcting is on my wish list for latter.  sort of imposible to watch linkage to find loose section by your self.
Joe,  I would gladly drop down there to help with that, but you're aware of my newest commitments.  My schedule might be free enough if you head north this weekend, as I'll probably be stuck in Rocky Mount.  We could also address it at Fleet Fest assuming one of the trailer folks brings a floor jack.  Or possibly even at my house earlier that departure day, just I hate to be adjusting it under time pressure and possibly making it worse before better (it could happen).  I personally have had good experience with the (basically Hall I think) spherical trunion, though I have seen arguments for stock in the long run, but I don't put that much mileage on mine.  I'm basically now probably also wearing out some fabric going into R, but I am comfortably back to keeping my shift gate in.  Obviously, the trunion nut must be tight. - Lee
no adjustment attempted.   I did notice one connection.   the "nipple" on the ZF shifter input shaft.   with zf in 4th, the "nipple" could be wiggled to move the sifter about the amount machined.    during drive, if shifter pushed max right (where milled away) it would go into 4th, BUT if pushed to where 4 th gate should be, it could go into 2nd (MONEY SHIFT)
  • mceclip0
the input shaft does not wiggle (well veryverylittle).   the nipple that is pinned to that shaft is wiggling.   not much at that diameter, but is significant at the shifter.
my gut feeling for repair is to drill/ream the pin hole larger and new fitted pin.
just the location would require right hand drill and a steadier hand than mine
without the gate is the way to go, BUT just for looks, I want a gate
using a distrubuter so just single spark.   since I've had it back the performance has been questionable, but this is embarrising and probably doing damage.
In fact I think that right muffler is restricting as the pulse of "normal" is very noticably less than left side.
right now I'm just going to leave it parked.   we've got a week of heavy rains and wind
