there are a@ 5/6 spot welds that hold the bracket down [ look like dimples in the bracket] need ab to drill an 1/8 hole thru bracket only in each dimple then go back with a 1/4 bit to remove the weld. fwiw both brackets i have removed half the spot welds had no penetration once you do the pilot holes grab the bracket with a pair of vice grips and wiggle it up and down, i t may break the weld off.
