issues are
a). no horn have power to relay will ck the horns themselves but if they work is the issue in the turn signal switch?
b). oil temp gauge po wired in had sensor wire clipped
i ordered an electric one to fill the hole where do i tap into 12 v?
c). no dash or gauge lights the courtesy light on all the time can i use that courtesy light wiring as power source? the is a 'plug' down by the reostat in driver side footwell w black and yellow wires coming from it but not plugged in. is that the problem?
d). no power to cigar lighter. i dont smoke but would like to power my garman or ipod. is the power to the lighter the pink wire that is not hot or the 'blue' wire that is clipped? cant get answer by pondering the wiring diagrams
I HAVE HORNS WOOO HOOO po had clipped the brown ground wire at the turn signal
I HAVE OIL TEMP the thermal couple had been clipped, replaced with electrical unit
I HAVE LIGHTS TO CENTER CONSUL had to bypass one of the yellow/black wires
NO SPEEDO /TACH LIGHTS seems to be problem past the white plastic connector will try get tach out and rewire RHEOSTATS ARE HISTORY
CIGAR LIGHTER CONVERTED TO POWER PORT
FRIED STEREO ON AMMETER whoops well taking it in to have massive amp and cd changer removed cant hear it anyway hopefully is just a fuse
CONSUL COURTESY LIGHT COMES ON WITH HEADLIGHTS low priority item but will try to get at that
NO BACKUP LIGHT OR REAR VIEW CAMERA can anyone tell me how transaxle activates the bu light switch?
thanks for all the help and support
joe
