Originally posted by JFFR:
I got tired of fuel pressure issues. I had a fuel pressure gauge in the fuel rail in the engine compartment.
I installed a fuel pressure gauge in the dash where I can watch it. It has an electric sender so there is no fuel line in the cabin.
Nice set up! I though I was the only Pantera owner with a vacuum gauge. Of course I also have a fuel pressure gauge, oil temperature, fuel air ratio and outside air temperature gauge. I just can't seem to get enough information, but with EFI it is nice to know what your fuel pressure is on your system.
I put a vacuum gauge in the dash also.
This car in particular, for me, needs more information then originally supplied by the stock instumentation.
If I was going to race seriously, I probably could justify an oil temp gauge also. On the street with an oil cooler and a 10qt Aviad pan you don't need one to tell you the oil is too hot. Not at all. It takes a while for the oil to heat itself up.
What you are not seeing in mine is the LED's added. They are less intrusive then gauges.
The additional vacuum gauge and fuel pressure gauge help me the way this car is set up. Those two alone give a wealth of information including whether there are fouled or fouling spark plugs.
One of the LED's tells me when the auxiliary oil cooler fan turns itself on. There is another for low oil pressure. Another for high water temp.
Some blink, some just show a solid color.
With Webers fuel pressure is critical. With EFI it is also. It helps to know where all levels are at with just a glance.
Jon Haas has LED's in all of his electronic devices. None are driver accessible. They are for device status monitoring. Those are good ideas but you don't crawl under the dash to monitor them when you are driving.
When I did the fuse panel, I got the version with the volt meter built into it. When analyzing an issue, that can help, but that is when the car is in the shop, not when driving it.
I have this vision of having radar detection built into the dash inconspicuously but that would take up critical space in the dash.
The other reality with instruments is that when you are driving a vehicle at speed, the driver is looking down the road. FAR DOWN THE ROAD. Every heartbeat of time might be the length of a football field distance wise.
I know that I can not look down at my instruments, my eyes focus in detail and read them instantaneously after driving "at speed". Those dials are just a blur and I can only see "about" where those needles are pointing.
This is why if you look at the gauges in many race cars, the gauges are all adjusted to a point where when everything is about right, the needles all point in one direction, usually all to the top.
A driver at speed taking their eyes off of the road even for an instant could be catastrophic.
Many times more gauges just adds more confusion to a driver. In a sense, the quantity of gauges should be limited. That's my choice, anyway?
Current instrumentation in F1 cars is a good example of limiting the info to one point where the driver can focus on with a glance.
One could argue that the counterpoint would be something like a Ferrari "Daytona" 365GTB where seemingly there is a gauge for everything? To me, some of those gauges are close to useless and just there as a design statement of automotive jewellery.
The dials on these gauges are all coordinated. Where the needles are pointing makes sense to me and helps instantaneous focus?
What would have been perfect for me here in my gauge set up would be if the speedometer could be reversed indicating on the dial like the Smiths speedo in the Cobra is? Then all the pointers would be sync'd to the center making them simpler to read at speed, all pointers starting pointing at center?
You can get a better idea of what I mean in this closer up pic.
I now return you back to your regularly scheduled programming. Sorry for the side trip. I do try to make it entertaining though in hopes of a good review?
