@with regards …no apologies needed - this is exactly what is needed to make decisions what to put in an engine for what expectations… this is info for everyone … I think the original downfall of the Cleveland in the Pantera was the low compression… you get it in the 10.5 : 1 (that’s probably tops for the 91 octan gas we have here) and a bit of cam the 400hp should show up easily…
(what do you mean with ******** -nasty?-) cam, Valve Springs, titanium intake valves. rrrrrrpmmmmm
@simon I agree that a smaller carburetor like a 650 would provide better drive-ability at lower RPMs, but I am not sure if you’re not running out of carburetor at higher RPMs just because the Cleveland heads flow a lot more… (but it may be OK on the low compression stock engine ) there are two calculations… If you look what they say for cubic inches and the size of carburetor for that — and if you look at the cfm to support how many hp…
Those who do a lot of dyno work will tell you larger carbs usually show an increase in horsepower at the top end. How the engine will actually be used and how much time it spends at max RPM versus how much time at idle and part throttle determine the best carb choice. (Stolen)
my engine is a 393 cubic inch… and my 750cfm is probably on the low end of cfm for this engine … combined with vacuum secondary (which do not have the enrichment at the second stage like the manual), it should make it a nice driver but loose a bit at top rpm..
