Found it! And I have to say I am very surprised that i found nothing related to that topic here.
The chirp came from the perforated inlet in the tailpipes. The space between this tube an the outer tailpipe originally was filled with damping material, which burns out over time.
And because the tube itself is only welded on one side (towards the muffler), when the stonewool (or whatever it is) is gone, it can freely move, which it does unfortunately.
The chirp is gone after removing the perforated tube.
In this link you can hear the chirp on the third Pantera in comparison.
https://www.youtube.com/watch?...channel=laurent91400
As always: sorry for my bad english
  • IMG-20220528-WA0005
GeorgS - thanks for the follow-up. Were you able to hear the loose inlet pipe when banging on the muffler?
My chirp noise appears to be acoustic vs. a rattling internal part. I can control the sound by blocking one of the outlet pipes and, I need to verify this, but I also think I was able to control the chirp as I was adjusting the idle mixture on a new carb. As I was richening the mixture, the chirp seemed to go away???
No, banging against the muffler had no effect.
I made a video of testing with steel tubes inside the tailpipes ( seems like Simon did the same).
You can hear me talking in German but it doesn't matter, I state the obvious: "noise is there" and "noise is gone", watch till the end, you can see that you don't even need the tubes.
I am sorry Rob, I see you live in Michigan, that is a bit far to take a quick look.
Videos (1)
VID-20220514-WA0001
Way back when we first bought our '72 in 1980, one stock muffler 'jingled' at idle. Turned out that ANSA had added a "final baffle" inside each muffler by tack-welding a steel washer inside the muffler onto the perforated outlet pipes.  And in 8 yrs of driving, the tack-welds broke in one side, freeing the washer to fall into the muffler case to rattle around.
Cutting a little hole in the case allowed enough access to dump the thing out. Then I took a piece of steel pipe and stuck it in the still quiet muffler outlets. A sharp whack on the pipe end easily broke those washers off too and I removed all of them the same way. The noise increase from the four broken 'final baffles' was un-noticeable.
IMHO, anyone not rather well to-do that owns any Italian car and does NOT own a large selection of tools, welding equipment and a lathe, is fighting an uphill battle if he/she expects to  drive it regularly! Sure- there are shops that do this stuff every day.... at $80-$125/hr. And they have waiting lists.
I cut/sawed the tailpipes behind the original weld (see picture).
But don't cut them off completely, or you will have a lot of fun welding them back on in the correct angle.
I just cut as far as I had to till the perforated tube could be removed.
Then welded everything back together, grinding and sanding fun and at last painting it black again.
And yes I have to agree, if you are not able to help yourself, it will be very difficult to have fun with these cars. The problem here is, that there are no talented mechanics that I trust enough.
  • IMG-20220528-WA0004
As an alternative to removing the perforated tubes, Ansa GTS Exhaust chirping can also be eliminated by covering perforated tube holes.
I purchased four 8" sections of "Mild Steel Round Tube 1026 (DOM) 1.500 X 0.065" from Metal Supermarkets (local pickup $35.83 all in), inserted these solid tubes inside the perforated tubes, secured with 1/2" long #8 sheet metal screws and voila - no more chirping.
