Originally posted by zfett:
I just made a deal locally on used headers and new flow masters and pipes all will be jet coated. Thanks....Bob
zfett:
Make sure you tell the Jet-Hot folks NOT to coat the INSIDE of the mufflers. There is no way to remove all of the tiny round pellets that are 'sandblasted' to prepare the surface and they will be trapped inside the new flow master mufflers forever, possibly even sucked up into the engine when the engine is started and the exhaust ports temporarily create vacuum before the engine ignites. You don't want your new mufflers to sound like those mariachi shaker things the Mexican bands use. Jet-Hot is great inside and outside the headers though. For the mufflers, stuff rags in all the tips and inlet pipe and put a big note on each muffler assembly.... Tape off the tips if you want them left chromed and another big note on each set of mufflers. Better safe than sorry.
