I found this old post dated 2005 but its closed so I could not reply.
Air craft style gas filler
Marlin had done some nice work on a few filler doors. The last page has a link to Get Real Performance which looks very interesting.
Has anyone used the Get Real Performance version of cap? How much machining to the gill is required? I have the external fuel door in the gill now. How much cutting to the sheet metal in the car with this version?
Are there any other options out there for this mod?
Steve
  • get_real_performance
i'll get a couple of more photos and post, but 3 strong magnets are panel bonded to the gill and the hold her shut, also have a thin wire cable to hold it from openng too far and scratching the paint, have had it up to 100mph and still remained closed , have only had car on road for the past couple of weeks, will get more completed pics up soon.
cheers guys cj
The first of those type fuel doors were from surplus or home-built aircraft (WWW.aircraft-spruce.com) in the L.A. area, but a few were ex-motorcycle gas tank caps. As for options, I left the stock L outside filler door on the left and duplicated the entire thing as a mirror image on the right side. The new right side door covers the radaitor cap attached to a larger aluminum surge tank. Just in case I didn't like its looks, I didn't cut the stock die-cast gill but made a silicone rubber mold of it, then cast a new gill out of fiberglas & resin, and cut that up. But since it's been on there since 2002, I think its there to stay....
Now thinking about routing the oil dipstick under that door too, so I can check all engine needs without opening the decklid. I moved the stock dipstick to the rear of a 10-qt Aviaid oil pan sump, so it's pretty much right there anyway, but the 3-1/2" door is kind of cramped for space. Needs more thought this winter.
My fuel cap is fairly basic.
I went for the race look & installed the Aston Martin 60’s type race cap similar to what the GR4 had.
I took a mould off of the original louver panel so I did not have to cut up the original aluminium part.
Made a new louver panel in Fibreglass.
I really like Chris’s installation, very stealth !
Regards,
Tony.
  • New_fuel_cap_copy
we had good fabricators in the shop and made a recessed panel to fit the aero cap into. ( if not recessed cap would make gill sit out from car.), so had to cut hole in car panel and panel bond new panel in place used the cap and some alloi strips to hold in place to set panel bond.
angain if we had thought of this sooner could have spot welded into place and would have seemed factor.
also would have prefered a large hole saw as cutting freehand was ok but not perfect.
  • IMG_0595
note that this is a double hinge system if the gill is hing directly to the impreza hinge the angel is wrong and the gill will not be able to open very far and will chip car paint work.
we just welded a comerical hinge from hardware store to the car hinge. and then panel bonded the hardware store hinge to the the gill. sorry photos not great was thinking about making hte thing work not taking step by step pics. so am doing this in arears.
  • IMG_2225
have added a wire cabel to the car and the gill so that gill will not drop back too far and chip car paint.
I am using three strong about ¾ inch by 1/4 round magnets used for keeping cabinet doors closed to secure the whole system closed, seems to be working hit 120 mph yesterday and still not blowen off.
i didn't have a filler tube to go to the new cap so i bought a 2 in bend and faricated the thing to fit and its conected to the aero with fuel rated hose and SS hose clamp. the bend came out very well so we chromed it.
  • IMG_2226
photo of the pipe from tank to aero cap. you may have noticed another small black cap under the gill also. while i was doing this mod we decided to move the window washer tank from in the front to under the wheel arch also and have plumbed a new pump under there also. this just cleaned up the front trunk alittle more.
looking at this pic i need to do some dusting.
hope this is of interest, if any more question plez ask. cheers all cj
  • IMG_2227
Hi, Pantera Performance Center in Castle Rock can machine your side panel and they have a complete setup also available. I initially purchased one similar to the one you talked about, but the round key lock is kinda cheap, but the fit is better with the 45 degree angle than the straight one everybody uses. At least for my 71 it was.
