Just received the latest Summit catalog. It lists a "New" product,aluminum 351 Cleveland block. Really surprised and pleased to see this. And maybe it will bring forth additional Ford racing products for the CLE.
From the Summit listing:
"These Ford Racing 351 aluminum wet or dry sump race engine blocks feature cast iron sleeves, an all-aluminum water jacket, and oil galley plugs. They are manufactured from 356-T7 aluminum and feature siamesed cylinder bores, a 9.400 in. deck height, 4-bolt main journals with steel billet main caps, and 2.75 in. diameter main journals. At just 124 lbs., the Ford Racing 351 aluminum wet or dry sump engine blocks save a tremendous amount of weight over a standard cast iron block. The blocks will accept a standard wet or dry sump oiling system. Build a reliable, durable, high-horsepower engine with one of these Ford Racing 351 aluminum wet or dry sump engine blocks."
Okay George, a new project for you ?
http://www.summitracing.com/pa...1/overview/make/ford
