A few months back I got some energy to get my pantera working and driving again. I did the fuel pump, carb and fuel sender. Got ahead of myself and did some polish and cleaning on the paint. I repaired the water overflow bottle and more. Issues is I did find my brakes were dragging pretty bad. I thought it could be the emergency brake was stuck. Took the back wheels off and they turned ok so it wasnt that. Yes I did take the time to lube the emergency brake assy and the half shafts.
So this morning before it got 120 degrees I jacked up the front and checked the front wheels. Yeap both front wheels are very hard to move at all. I have driven it up and down the driveway to try to get them unstuck with my fingers crossed. But of course not, fingers did not work. So both front wheels are dragging heavily. What I am going to do is pump the pedal then open the bleeder to see it the fluid squirts out or just comes out normal. If it jets out I am thinking its the master maybe? If it dribbles out normaly I would think its the caliper? Does that sound right? So yeah I need to fond the cause so I can get to the repair.
At least for now it does start up when I ask it to and it does moves. Looks good but its in the garage so that doesnt count.
Thanks for any help as always.
