Problem.
1) Passenger headlight does not work on 'low', does work on High. Drivers light works properly.
2) Passenger amber running light is much brighter than drivers.
I replaceed both 1158 amber lights thinking that they were just old. No change.
I replaced the passenger headlight, no change. Measured voltage to low beam at plug and it looks like 9-10VDC. Voltage to drivers low beam is constant battery voltage.
All other exterior lights appear to operate correctly.
Suggestions before I dig into the prints? Thanks
John
Fixed. Found that front headlights are individually fused both side to side and hi/low. Fuse for the passenger side low was good, but the holder was so loose it's surprising the fuse even stayed in. Bent the clips, and the light works. The running light is still brighter, but perhaps it's an issue with the lens.. FYI
