Hello again,
The metal spacers located just below the chrome securing nut on the wipper pivot arm shafts are apparently frozen to the shafts. This is probably because of the two different metals Aluminum/Steel in contact here. Besides cutting a vertical slot in the upper spacer to split it off, has anyone had any experience in this situation. Also when in operation should there be any movement in the pivot arm assembly as the cable rotates with in it? In this case they do and I suspect this can be attributed to the spacer being frozen in a position allowing it move and can not be further tightened down by the nut.
Thanks in advance
