whats new what are the members using cop,cnp, distributor-less ez, holley or other ecu's price pictures performance etc.
quote:Originally posted by david 3449:
...... Also a stock charging system is marginal , the EFI system with a full time fuel pump adds 10+ amps and the injectors and computer a little bit more.
quote:Originally posted by Bosswrench:
Just be careful- a TBI pump runs at 8-12 psi (which I regulated down to 7-8 psi for my Holley). It looks identical to a Ford EFI pump which runs at 42-58 psi and CANNOT be regulated down far enough for a carburetor. And once out of a donor car, you cannot tell them apart until they start pumping. There are no tags & stencils would not withstand gasoline.
