Does anyone have experience with the fuel sending unit on a '71 Pantera? Doing a quick search, I see that they area available from $37. at JC Whitney, to $225 from Hall Pantera, and $169 from Precision Performance. They all look the same, and yet, none of them have a parts # or description. Anyone have any experience with this?
Many thanks!
KP
The Pantera sending unit is unique to the car as far as I know, and an OEM '71 assembly has not been available new since the last century. The new senders are ALL '73-up assemblies with an integral fuel-out pipe and will plug into any Pantera, but early cars must then plug the troublesom integrally-welded fuel-out line in the tank. I've fixed a couple by cannibalization but its not fun & not guaranteed. The senders were reproduced a few years ago by a group of vendors and all the vendors got in on the purchase afterward, which was over 300 senders. Call around- at least one has them at $145 with a new gasket & float. JC Whitney? You're on your own there....
Hi KP,
JC Whitney is not a Pantera vendor and will not have the Pantera Sending Unit. There is a difference between an older Pantera and a newer Pantera regarding the fuel pickup. Doing a search on this forum will get you that info.
Hall, Precision, Wilkinson will all be able to get you the part you need.
Take care, Scott
I tried rebuilding a few. I also transferred stock senders to larger fuel lines on a few for high-powered engines, since the stock sender fuel line will only support about 450 bhp; the flow restriction causes carbs to go lean above 5500 rpms. If you add an electric in-tank fuel pump, the small stock line works OK under the higher pressure from the electric pump. But then you need a good regulator between tank & carb.
The sender parts are similar to mid-'70s Alfas except for not being exact duplicates. There's a brittle plastic case (2 types) with an access window, a semi-curved wire-wound potentiometer and a long hardened steel arm, along with a few washers and a float. What goes south is usually the wire-wound potentiometer, and even pro electric gauge shops want no part of rewinding one of these. Alfa potentiometers do NOT interchange being wound out of different sized wire which changes the calibration. The floats interchange as well as some (but not all) outer cases and the gasket. The flange that screws to the gas tank is similar but the welded-on support struts inside are radically different for a tall Pantera fuel tank. The Alfa tank is smaller volume and flat. If you had two Pantera senders, you could cannibalize parts but opportunities for a mistake are many. Probably not worth the trouble for $140 brand new.
It has been common knowledge the Fiat X1/9 unit will work in the Pantera, although I'm not sure it is a direct interchange part. For a long time nothing else was available, but as discussed the vendors have reproduction units available now and $169 is a pretty damn good price IMO. If we don't support them when they gear up for this stuff then we can't complain when they aren't around anymore.
I do have an X1/9 unit on the shelf acquired some years back plus a Pantera unit out of the tank, so I'll do some comparisons when I get time.
Just for the record the following are side by side photos of the Pantera vs. Fiat X1/9 fuel sending unit. Will it fit? Yes, but it would need some bending and adapting to get the float in the correct orientation. It does have a return fuel line for anyone using or considering EFI.
  • IMG_2163a
A stock Ford EFI fuel pump will fit on the end of a stock sender if you're willing to do some adaption. An electric pump needs two extra sealed wire connectors not present on either of the senders (4 total), and the bottom end of the tube needs to be shortened by the length of the pump & its filter. Then you need a secure hose connection and a mechanical support for the pump.
To test the idea, I added a TBI electric pump (identical dimensions to an EFI pump) to our OEM Pantera sender. TBI pumps only put out 10-12 psi and can be regulated down to 8 psi for carbs without pump damage, while EFI pumps cannot. The finished assembly fits thru the stock tank opening and works fine as a backup fuel supply on my carbureted 351C. The advantage of an in-tank pump are: better protection, no suction problems & no vapor lock, with quiet operation compared to outside mounts. Note this was a STOCK Ford pump; oversized aftermarket pumps likely won't fit thru the opening. There's room on a Pantera sender top for the two extra sealed wire connections; not sure about the FIAT sender. Written up in the POCA Newsletter a couple of years ago & still working as of today.
To fit the X-19 sender in a carbureted Pantera, be prepared to chop off or sharply bend the two hose bibs for engine cover clearance. Smooth bends are better for good fuel flow. When you alter the hose bibs & install, maintain the stock clocking so the float arm fits the Pantera tank baffling, while lining up the bolt holes.
