I recently purchased a new gas tank sending unit from a vendor. Prior to installing it I did a bench test and found it doesn't seem to work. I hooked up my old one and it works fine (I'm switching to the new style due to an apparent hole in the suction pipe in the tank). Any have this issue also? It also has only two terminals. Did they do away with the warning light on '72s?
