I have now renewed both the clutch master and slave cylinders.
have a new McLeod pressure plate fitted, the no bob weight type.
I had the spinner plate relined.
a new release bearing
very difficult to engage a gear with the engine running, engine stopped all select well and the lever position is OK.
There seems to be a clattering noise from the bell housing when running!!!!!!!!!
so Can I remove the Gearbox and leave the engine in place to see whats going on.
Must say I'm Baffled here.
