this is an early car and I need the lense only I would have to see a pic to tell you exactly witch one I have . The ones on the car have a large clear reverse light if that helps George
There are several variants of lights (and lenses). Some have the mounting bolts in different places. Confirm what you need, and post an image, if you can. Chuck
It will say Altissimo or Carello on the lense (they both look similar, except the Altissimo has a pattern design in the lense similar to the red and amber sections).
