I think you need 10" and 13" wide wheels for a flaired car. I just installed a set of Hall's 15"x10" and 15'x13" (with 185/345 P7s) on my 72 with GT5 flairs and they fit and look great.
quote:Originally posted by rudy123395: I think you need 10" and 13" wide wheels for a flaired car. I just installed a set of Hall's 15"x10" and 15'x13" (with 185/345 P7s) on my 72 with GT5 flairs and they fit and look great.
For the fronts did you run 185/40's? Looking for some myself if you know where I might find some.
Luckily the tires came with the wheels which I found on e-bay. I'm probably SOL when the front tires go, but that's off in the future. Every once in a while I come across some Yokohama 185x15's but they're expensive. I just don't like the bigger 17" wheels, but to each his or her own.
