Same thing happened to me. Not the headlights but the dash lights went out. Turned out to be the rotary dimmer switch to the left of the steering column. Stopped letting any current through at all. Pull the two wires off the dimmer and connect a jumper wire.If the console lights come back on problem solved. Not so sure about the headlights but you might get lucky. I just left the jumper in and did away with the dimmer. Good Luck
Doug M
