I installed the low profile headlights and discovered the car had some body damage on the drivers side at one time. The drivers side upper fender around the headlight is new sheet metal.
had some fitment issues but got that taken care of but, the drivers headlight is 3/8” higher than the passenger. Does anyone know how or if that rod is adjustable? If I could get the drivers side to tilt down 3/8” it would be perfect.
Dan
As Marlin said, lots of ways to fix but none are simple 'adjustments'. Note the connecting tube for the two buckets rotates in split nylon bushings in lightweight sheet metal brackets inside the fenders. It's possible one or both brackets are twisted a little. Or one bracket has no bushing. The vendors stock spares and they replace fairly easily.
