I had the car up on the Quick Lift and was looking around the rear wheel well on the driver side and found something loose and dangling.  When I moved the part it freely clunked against the inside of the rear fender and the gas tank.  It turned out to be the drain line for the gas cap cavity in the gill.  The hose appears to be original.  If so it is now 50 years old.  In any case it is almost rock hard.  Everything in there is black and the drain line was well camouflaged.  I replaced it with a fresh piece of soft tubing.  The nut driver is in the photo to give perspective to the length of the hose.
EBE7E207-5636-4F92-AD91-76B2E4936BDB_1_201_a
  • EBE7E207-5636-4F92-AD91-76B2E4936BDB_1_201_a
