What would be the issues with increasing the cooling system pressure from 13 psi to 16psi to give a higher boiling point to the coolant?
quote:Originally posted by PanteraDoug:
It's only a 3 psi increase. If I consider why current production vehicles run 16 it is basically for more boil over security.
When these components are tested, it is with thirty or forty psi.
Am I going to inflate the brass? Not with only 16 psi yet if provides a safety factor for boil over.
That thought certainly seems to fit into my concept of the Pantera.
I'm not going to argue with anyone. I just want to hear some feedback. At this point, kicking this around can't hurt.
If a thirty year old heater core is suspect then what about my thirty year old radiator?
Keep those thought coming. Yes, even you Mark.
OK. If I increase the pressure does it increase the velocity through the system?
Removing the surge tank may be a good way of improveing the system.
I suppose that can be as simple as splicing in a Moroso T with a filler car? Why is the surge tank need at all?
quote:Originally posted by deeb:
Just curious, but why increase the pressure?
There are a lot of better, simpler and cheaper ways to improve cooling. Such improvements are necessary on a 30 yr old car and when done overheating becomes a distant memory.
I have over 520 hp and still use the stock water pump. Compression is 10.5:1.
Even with my old stock rad I could sit in traffic all day and barely break 200 degrees. With my new Fluidyne, even after a high speed run on the highway I can sit idling in the 90 degree sunshine in my driveway and barely get to 200 degrees.
On the highway I have to turn my fans off or I would drop to 160 degrees. And that's on a hot day!
I think it has more to do with good new cooling tubes, hoses and a proper thermostat - along with good engine circulation, ventilation and oiling systems.
Keep going everyone. I love this hissyfit stuff.
I'm still thinking what harm can I do by going to 16 psi? I still need to look at the chart but won't that give me a 260 boil over? I think so.
I am tempted to make a data chart and record what everyone has done. Radiators, waterpumps, variations from stock on the plumbing, vs results.
Many years ago Gary Hall told me that the stock system is fine with a 160 thermostat in it. He said that the engine will run at normal temperatures with it because the problem is the distance from the engine to the radiator.
The distance is good for a 20 degree difference.
He said that if you do anything, put the Phoenix radiator in the car.
I am not preaching to anyone here. I am just repeating what I was told. How many Panteras do you think Hall fixed? A couple of hundred maybe?
I don't have the credentials to debate with Gary.
I will say that more then any vehicle I have ever been involved with the Pantera gets more overreactions then anything I've ever seen. On absolutely every subject, except one maybe, the a/c.
You know me? I do not like to be critical of anyone now, right?
quote:Gary Hall did more for the Pantera than any single individual anywhere. If it had not been for him getting into the parts business and trying to keep his car's running, this car may have just been a foot note in automotive history.
quote:A 160 degree thermostat is running your engine too cold and causing a lot of wear. Don't assume it will run hotter because of coolant flow distances, because it won't on a cold day and a 160 degree unit when it is full open won't flow any more water than a 180 degree one. The stock fan set up that blows through the radiator is not efficient. The ones that pull air throught work much better. From my memory of the Hall Phoenix radiator, it seems that it was thicker than the stock unit and did not flow air through it as well.
I am not arguing, I am interpreting what he said differently. My interpretation is that in a Pantera, a 160 thermostat is the equivelent of a 182 in another car.
The thermostat flows no more coolant but becasuse the coolant needs to travel further to the radiator it needs a head start to get there to keep the coolant at 182. Particularly under summer desert conditions.
I'm in southern NY. A high percentage of my Pantera driving eliminates cold temperature driving.
With a stock '73 water coolant system and a 160 thermostat, guess what? The car runs right around 185. Amazing?
Maybe it's my polished stainless cooling pipes?
Or my corrected Wieand pump?
Under these conditions, I probably don't need a 16 psi system but I still haven't convinced myself why it's a bad idea.
My best answer to myself is if it isn't broken don't fix it and leave well enough alone.
