midenginemike#3482 Grabber Blue 72 393 stroker CHI heads
OK...I will give it up---Its a 2002 Cougar trunk/cargo light. The lens needs some cutting with a Dremel to make it fit. Then bend out the tabs to hold the lens/bezel on. The best part, it only cost @ $12.00
I bought mine new thru my local Ford/Mercury dealer. Part # YS2Z-13A756-AA On the package it says--Made In Germany, so it kinda belongs on a Pantera. I dont think those Cougars were very good sellers so Im not sure how many you will find at your local salvage yard.
